Accelerator Issues
  • Accelerator Issues
    2015 Club Car Precedent. Issues with accelerator. Cart fully charged and batteries tested great. When I push the accelerator, the solenoid clicks, but it will not move. When I push the pedal a few times (sometimes it's just once, other times it's 3-4 pushes) it will move. I replaced the solenoid and MCOR, but I'm still having the same problem. I use the cart primarily on the weekends/holidays for golf. I keep the cart plugged in during the week, so it's always charged. I'm out of ideas. Can anyone help.
    I signed up on this forum yesterday also, I am replacing my lead acid batteries with Lithium Iron Phosphate. I had some general questions that I posted but have not had any responses. I would recommend going to eManualOnline and get the manual for your cart. There is troubleshooting section in there that might shed some light on your issues. You will need a multimeter to check ohms and voltages, Harbor Freight sells some that will even do AC/DC current. Your gas pedal is attached to some type of potentiometer (variable resistor) which will send a variable voltage to the motor controller, which will send a variable voltage/current to the dc motor. When all this works properly you get to go play golf. Good luck.......... Rick Wilkinson
      Thanks Rick
