I want to make the move to a controller. Does anyone have info on how to do this.
Need help 03 CC DS coil to controller
You will need to get someone with a handheld Programmer to program it, Yes it looks like it will work It is pictured with a reversing contactor And solenoid But there is no mention of them in the description? It is a Stock Size 275 at the unit What do you use your cart for.
You will need to email them it should come with a stock program installed. Then you make changes after it's in the cart and program for your needs and your cards ability. Stock may work just fine And if you're going to add 1 more battery you mig ht not want to program now anyway.
I hit pay dirt today. A local cart guy called and they took in a 6 pass limo cart that is an 03 Club Car DS 48 volt. He is going to make a big block gasser so I get all the old electric setup and charger. All should just bolt in. Now I need to get battery's. I am a happy camper. Got the 8 inch lift installed, found a set of seats from a bus with seat belts to install after to frame has 24 inch added to it. I am going for a buggy look as it will be a 2 seater with a bed over the back where the seat is now. I have a pic of a cart that has this setup.Attached Files
Golf Carts Forum
