How Often Do I service brake pads?
  • How Often Do I service brake pads?
    Brake pads are made to last many years depending on the amount you use them. It is recommended to service your brakes annually or every 250-300 hours of use.
    The brakes are most commonly found under the driver side and passenger side rear wheels.
    Key Tips:
    • Examine and replace pads if necessary.
    • Use compressed air to clean brake dust.
    • If replacement pads are not needed, adjust brakes until desired performance is met. (Refer to your owners manual)
    • Lubricate moving parts as required. Do not lubricate cables or emergency brake latch.
