How do I remove the governor!
  • How do I remove the governor!
    The governor on your cart is there for a reason. It is possible to remove your governor and you may gain speed from it. Even better, it is free. But before you try something like this, please take a look at the things involved.
    Pros:
    Gain Speed
    Accelerate Performance
    Cons:
    Overheating
    Over-revving
    Seize
    Snapped connecting rods
    Melting internal components
    The list keeps going on......
    Check it out, today's going price for a refurbished engine on any golf cart is about $2000.00.
    So please THINK before you DO. If you want to remove your golf cart governor, purchase and install a tachometer. This can keep you in control and less the chances of the above happening to you!
    I wanna put mine back! Help?
      I think on the G1's there is a spring that goes to the rear differential, if you remove the spring or tighten the bolt, it modifies the governor.
        if you do defeat the govenor then install a tach and keeo the rpm's under 3800. golf cart engines were not designed to run at high rpm's
        sigpic
          the clutches wont handle it either !! they wernt designed to go over a certain rpm.
            Hello ALL,
            In all the searches to remove the governor...most respond to the "T" shaped arm (gold) but I must be blind LOL because there is nothing "T" shaped or Gold on or near the transmission. I have a 97 Club Car and it has one cable coming from the gas pedal - connected to a flat piece of metal...and then off that piece of metal is another cable that runs to the engine...both have springs attached to the bar?????
            Any help or suggestions would be appreciated.
            Thanks,
              On a club car a wire tie in the spring within a spring so that there is almost no movement works. We had rental cart at racing events so I always he'd the fastest cart. Nothing party's like a rental as they say. Works on easygo as well
